Hello FM,
When I want to look for my DXCC status the 4m band is not showing, it's showing in the grids and in my settings it's checked.
How can I see my DXCC status on 4m ?
Thanks for reply.
Rudi / ON7CL
Awards / DXCC status
Moderator: OE6CLD
Re: Awards / DXCC status
I had the same problem and edited awards.xml , now i can select the 4M band in the DXCC award status.
But LOG4OM is acting strange. i tried to add the 4meter band to all award sections in the "awards.xml" file , but then things got broken and i was not able to select anything. Strange is also the 70cm band is not declared anywhere in the "award.xml" file , however it is showing up in the DXCC MIXED status and other MIXED awards, but i was not able to get the 4 meter band show up there.
What i did is only add the 4meter award definition to "awards.xml" at the top of the file, starting at line number 183 i added:
That is between 6 meter en 2 meter award section, and now i can select the 4 meter band from the DXCC status dropdown menu.
If you try this , please make a copy of your "awards.xml" file first, so you can always go back to the original version.
Code: Select all
<Award>
<AwardCode>DXCC_4M</AwardCode>
<Band>4m</Band>
<AwardSearchParameters>
<QueryParameter>
<ParamOperator>=</ParamOperator>
<ParamValue>4m</ParamValue>
<ParamName>BandParam</ParamName>
<TableColumn>band</TableColumn>
<Query />
</QueryParameter>
</AwardSearchParameters>
<AwardSponsor>ARRL</AwardSponsor>
<AwardName>DXCC 4m</AwardName>
<AutonomousAward>false</AutonomousAward>
<AdifValue>DXCC_BAND</AdifValue>
<AwardAlias>DXCC-4</AwardAlias>
</Award>
You just found a bug and it must have been like this for ages!
I will get Lele to fix it for the next maintenance release
73, Robert SP8SN
I don't believe that Dxcc incĺudes 60m, perhaps Chuck can advise?
Marcus Sutliff/N5ZY
Edmond Amateur Radio Society President
License Class Coordinator.
ARRL Volunteer Examiner
http://www.k5eok.org
http://www.qrz.com/db/N5ZY
