Contests
M6VWX
Re: Contests
Post by M6VWX » 23 Aug 2018, 11:30
Thanks to all for your help .
Graham (M6VWX)
Re: Contests
Post by DF5WW » 23 Aug 2018, 16:14
Some final words from me. I use special contest loggers if i operate in a contest. Those logger can handle
all the formats you need and also the calculation oft the points is correct. After the contest i export as
ADIF and importing it into Log4OM which is my main logger.
For me the easiest way ;) ;)
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Ailunce HS2 (20W and 5W VHF/UHF) to LPDA´s and different vertical´s ...
