Blank cluster window on one installation
M6VMO
Post by M6VMO »
I have installed LOG4OM on two different machines.
The problem is, on one installation the cluster window shows all the clusters beautifully, while on the other one, a blank screen stares me in the face.
As far as I can see, all my configurations are identical.
Has anyone got any idea what could be causing this?
Cheers.
Frankie.
73 de M6VMO
Slough, Berkshire, England
https://www.m6vmo.tk
va3vf
Re: Blank cluster window on one installation
Post by va3vf »
M6VMO wrote: 22 Jan 2020, 15:15
Long shot...
Are you running both installs at the same time? Some clusters only allow one session per user. If that's the case, the other installation will need to access a diferent cluster.
73 de Vince
M6VMO
Post by M6VMO »
va3vf wrote: 22 Jan 2020, 16:30 Long shot...
73 de Vince
No, I run both installs separately.
I installed them on two machines in order to work with two radios.
One is a fixed mobile rig and the other one is a handie which I use in a different room and hence I use a different machine to run it on.
Thank you.
Frankie.
73 de M6VMO
Frankie,
Are you logging into the same cluster from the two separate machines?
If you are you should use an SSID identifier with your cluster logins. Reason being as that some clusters will fuss at you when using the same login from two different machines.
In my case I will use: KI5IO-0, KI5IO-1, KI5IO-2 ... etc., etc..
M6VMO
Post by M6VMO »
KI5IO wrote: 22 Jan 2020, 18:19 Are you logging into the same cluster from the two separate machines?
No, I am not, Nolan.
I use different clusters on both machines.
Thank you for this handy tip, though.
Frankie.
73 de M6VMO
M6VMO
Post by M6VMO »
Thank you everyone.
I just reset the offending one to factory settings and it now works as it should.
Frankie.
73 de M6VMO
