Appears that the "Send Command" in Cluster Management doesn't send anything.
Doesn't matter whether "Send to all server" is checked or not.
de Mike W9MDB
Cluster send command not working
Re: Cluster send command not working
Also...don't see where one can edit the script to connect to the clusters.
Disconnect the connection to the cluster then head over to the Connection tab. There you'll find the pre defined Cluster servers. You can add your own or edit an existing entry with that little pencil icon. Save it when done with editing.w9mdb wrote: 21 Jan 2020, 16:47 Also...don't see where one can edit the script to connect to the clusters.
Flex 6600 - Spiderbeam
I made the same observation. Disconnect ad Reconnect the Cluster then it will work for a "while" until it occasionally seems to stop working.w9mdb wrote: 21 Jan 2020, 16:45 Appears that the "Send Command" in Cluster Management doesn't send anything.
de Mike W9MDB
I've tested the Send Command and have also disconnected and connected to clusters and have also have up to six clusters connected at once.
No drops, no disconnects and the Send Command worked for me.
Hi Roland,
Sorry, the resolution on your video makes it difficult to see what you are doing. Are you trying to send the SH/Filter command? And what cluster are you using?
I am using VE7CC and the Sh/filter commands works fine here.
Thanks,
Doug - W7DRM
Thanks,
Doug - W7DRM
Hi Doug,
the resolution of the video is 1080p, HD resolution. You can take any cluster and any command same effect.
If I disconnect and reconnect the "Send command" works again for a while but then all of a sudden no output when you hit the button. I can replicate this issue every time after disconnect/connect and wait for some time.
Just cosmetics, nothing critical.
Roland
Roland
