It appears to me (correct me if wrong) that if I configure for use of N1MM (which I use only in contests), that I will lose CAT control when I return to "normal" operation. Is that true?
If it is true, then I assume that I could build a new configuration, call it "Contest", and invoke it when I use N1MM. Then return to "normal" configuration when running without N1MM. Is that also true?
N1MM Integration
Re: N1MM Integration
It's only a couple of clicks to restore CAT in Log4OM after your contest session so hardly worth setting up another config IMHO
Thanks, Terry, for the prompt answer.
I'll consider that as an option.
Meanwhile, is my "multi configuration" option described above a viable procedure?
So Terry, all the other settings can stay in place? You just need to enable/disable the cat?
You might want to uncheck the UDP connection also if your going that route, but only to save a little CPU activity
Terry, I've found another solution. It is described in a new thread.
