Where to save Country_user.xml ?
dl1clm
Post by dl1clm »
Can someone tell me where to save the custom Country.xml file, Country_user.xml.
I did it in the directory where Country.xml is but then it will not be read.
Then I put Country_user.xml in the 'user directory' but it won't be read there either.
In all cases Log4OM2 keeps showing the wrong CQ Zone value from Country.xml.
73 DIck DL1CLM
Optibeam OB 9-5
Re: Where to save Country_user.xml ?
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\user
dl1clm
Post by dl1clm »
Thanks for your reply Terry,
As I wrote in my message I saved Country_user.xml in the 'user' folder.
However after a restart of Log4OM2 the wrong value from the original Country.xml is still displayed.
I checked the location of my Country_user.xml again, see below.
73 Dick
Optibeam OB 9-5
Incorrect result may be coming from on line lookup, dissable on line look ups and check again
dl1clm
Post by dl1clm »
Hallo Terry,
If I enter the call PJ2 in the main screen, the wrong CQ zone 8 is showing up in the field.
If I then complete the call to PJ2LS, the incorrect value 8 will be replaced to the correct value CQ Zone 9.
This correct CQ Zone comes from QRZ.COM because QRZ.COM is entered as the primary info provider.
the correct CQ Zone 9 is in the file Country_user.xml in the user folder as you specified.
73, DIck
Optibeam OB 9-5
