There may be a problem with large LoTW uploads.
I just finished the ARRL DX contest and tried to upload my log to LoTW, about 900 QSO's.
The upload stalls with this screen showing forever.
I also have "upload to lotw on shutdown" active.
I shut down, then launched Log4OM again. The QSO's have not been uploaded.
I then used tqsl as a standalone app, and uploaded the log (as an adif from N1MM+), and it loaded without any complaints.
LOTW Upload stalls
Re: LOTW Upload stalls
Here's what appears in "real time log".
18:53:04.528 Info: [dje_zEL542B6XSJUH7MGDJAB8KA2MYGVA_ejd] : Massive upload of 901 on LOTW
18:53:07.371 Info: [LOTWManagement] : [LOTW UPLOAD] uploading LOG with 901 QSO
18:53:07.372 Info: [AdifManagement] : Begin export to ADIF file: E:\Log4OM Logs\LOTW_UPLOAD_20230220185307.adi
18:53:07.504 Info: * [AdifManagement][132 ms] : Export to ADIF file completed: 901 QSO
18:53:07.504 Info: [LOTWManagement] : [LOTW UPLOAD] TQSL Version 2.6.5
18:53:07.504 Info: [LOTWManagement] : [LOTW UPLOAD] No private TQSL Password set
18:53:07.504 Info: [LOTWManagement] : [LOTW UPLOAD] Executing TQSL with upload. Parameters: C:\Program Files (x86)\TrustedQSL\tqsl.exe
18:53:07.52 Info: [LOTWManagement] : LOTW MANAGED MODE
18:54:38.753 Info: [dje_zQB927KENQUQVBCFAD2S44_ejd] : Worked before list updated
18:54:38.769 Info: * [dje_zJEAMFK9M5WZDBS5J5AALC2SQ5TZA_ejd][202978 ms] : Recalculating statistics asynchronous process completed
Here is a screen clip showing the entire situation.
Have you checked to see if the qso's appear on the lotw website?
After three tries, they were not there.
I then uploaded an ADIF from N1MM+ directly with the TQSL app, and they soon appeared in LoTW.
The "LoTW Sent" column in Log4OM remains "Requested", treating them as not sent.
OK just select ten new QSO's that have not been uploaded to LOTW by any software and let me know if that works
I only had nine, but they uploaded normally, and Log4OM shows them sent.
Maybe 900 is too many?
Since I've already loaded them to LoTW via TQSL, is there a bulk way to mark them "Yes" in "LoTW Sent" column. I could select them in smaller batches and upload them I suppose, but I'd rather not send 900 duplicates to LoTW.
