Used to work fine just before the upgrade, Now I get this an error
"exception the operation has timed out. We don't have imagery at this zoom level in this region."
2.28 error on map
Re: 2.28 error on map
The callsign of the station to check ? I have worked some stations 2day and the map was fine.
Martin,
What callsign in particular did y'all experience this with. That is what Juergen was asking.
If you could provide that or a few callsigns if experienced with more than one we can test and attempt to replicate.
Also which of the 3 Map Providers have you selected to use? Google Maps, Bing Maps or Open Street Maps
That setting is at: Settings / Configuration / Program Settings
I did not find "Grey Lane" on left Map...
Best 73
Jose EC6DX
Best 73
Jose EC6DX
EC6DX Balearic Islands
Jose,
Tnx for head's up. If you open the View / World Clock the 'gray line' does show up.
I'll give Lele a head's up to see about a fix for the lack of gray line in the Main (F6) panel.
- World-Clock.JPG (49.85 KiB) Viewed 1707 times
I installed new version today 2.29.0.0 and still not repared... it is a shame, because it was working in last versions...
If anybody know something about that, I will apreciate his help
Best 73
Jose EC6DX
Best 73
Jose EC6DX
Jose,
If you wait a moment or two or three the gray does show up. Not sure for the reason why the delay, but I'll ask Lele.
Update: Terry & I have done some testing and have experienced below ...
I have Log4OM on two "more mature" (IE: older) laptops and the gray line takes between 8 to 10 seconds before it appears and I also have a fiber optic internet connection.
Terry response for the gray line to appear is ~3 seconds.
Couple items of note: Terry's computer is far new/faster than my two older laptops and I'm also going to have Frontier check out and hopefully optimize my fiber network connection.
So, I don't think what you are experiencing is out of normal that is based on many factors as the tests that Terry and I have done have shown.
Hi
Yes, there is a small delay, but the color is very weak and it can hardly be seen with the map that I have configured (alternate 2) it can hardly be seen. I have tried the main map and it does look good, but I like the second map better since you can see the relief of the planet.
In 2 versions before, it was perfect... Best 73
Jose EC6DX
Jose EC6DX
Jose,
Got it ... I'm replicating that as well. I've just overlooked the very (VERY) faint gray line.
I've asked Terry & Lele to look into.
