hi
when are you plan to integrate MixW with your log???
MixW
Re: MixW
It's on our list but it depends when Daniele has the time to add it, however not long is my best answer.
At this time using Omnirig start MixW first and then Log4OM and the frequency/mode will be displayed in both, click on a spot and the rig will respond. You just have to export an ADIF from MixW and import it into Log4OM until we integrate.
Re: MixW
Any news about the MixW integration ???? Have downloaded ans installes latest MixW2 (Registered MW2 User) and it would be nice if there will be a way to Autolog to L4O ....
Normally i has worked with Fldigi but after change to Windows 10 Pro (64Bit) i don´t could get Fldigi (new installation) work. There is no possibility for me to setting up the soundcard entries, all is greyed out and the I/O decode is checken but i can´t uncheck
So i changed back to MixW that i can work a bit with digitals again
Re: MixW log location
Please concider the different version of MIXW-2 and -3 , the logs are at different location !
73 Hans DF2MC
73 Hans DF2MC
DF2MC wrote:Please concider the different version of MIXW-2 and -3 , the logs are at different location !
73 Hans DF2MC
The QSO is not extracted from the MixW log it is a direct interface transmission from MixW to an external logging program as a QSO is added in MixW
Re: MixW
As it looks as if MixW (both v2 and 3) is no longer being developed, I wonder if the Log4OM team should spend too much time on this?
I am glad that Terry saved Lele from spending money on an abandonware licence.
Re: MixW
Meanwhile i´m back on Fldigi
After a clean install of Windows 10 i got it to work. For now i am happy but would be nice to see a MixW integration in the future, Think some guys are working with MixW ...
