DPF - Diplôme des Provinces Françaises
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the DPF - Diplôme des Provinces Françaises. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_DPF.xml) into the <user>/AppData/Roaming/LogOM/awards folder (or in the config/awards folder if you're using the portable version) and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://ddfm.free.fr/
Claus, EI7JZ/OE6CLD
award_DPF.xml
(15.66 KiB) Downloaded 881 times
Claus, OE6CLD/DJ0DX/EI7JZ
F4BPO
Re: DPF - Diplôme des Provinces Françaises
Post by F4BPO »
DPF is missing two regions :
- Corse
- Provence-Alpes-Côte d'Azur
There are a total of 22 regions, in L4O only 20 are there.
Any chance to update ?
73 de F4BPO Greg
HS0ZLE wrote:Hi,
- Corse
You can add them yourself in the awards manager and then send Claus the xml file!
OE6CLD
Post by OE6CLD »
Hi Greg,
I also have corrected the Diplôme des Provinces Françaises award. Please update your awards to get the updated version.
You only will see 21 regions in France, because one region is Corsica, which is an own DXCC entity. You will see Corse (09) when you add this to a station in Corsica.
Claus, EI7JZ/OE6CLD
Claus,
Did you fix the USA counties award?
