Adding a QSO to Log4OM via WCF
Post by IW3HMH » 25 Jan 2013, 09:47
Log4OM supports integration via Windows Communications Foundations classes.
You can add a QSO to Log4OM using this way (WCF) connecting to the http URL of the software. WCF Configuration is managed from Log4OM configuration screen, default is: http://localhost:8080/log4om
WSDL can be obtained here: http://localhost:8080/log4om?wsdl (or in the path you choosed)
In .NET environment you should create a Service Reference from your software using the WSDL path, and then use something like:
Code: Select all
        private void btConnectionTest_Click(object sender, EventArgs e)
            try
                Log4omServiceReference.WCFServiceClient client = new Log4omServiceReference.WCFServiceClient();
                MessageBox.Show(client.ConnectionTest().ToString());
            catch (Exception exc)
                MessageBox.Show(exc.Message, "ERROR", MessageBoxButtons.OK, MessageBoxIcon.Error);
This message returns TRUE if you're correctly connected with WCF service. If the answer is positive, you're connected!
Other functions to put/get qso from log4om will be discussed later.
PB4FUN
Re: Adding a QSO to Log4OM via WCF
Post by PB4FUN » 24 Oct 2015, 08:02
When can I expect this ?
It has been more than 2 years since "later".
Post by IW3HMH » 31 Oct 2015, 22:22
Well, when someone seems interested :-)
