More cluster details on right click
yt9tp
Post by yt9tp » 31 Dec 2015, 10:23
In Cluster, when user clicks on call with right mouse button dialog pops up showing recent notes on that call.
I would suggest to add some improvements:
- show all details about call available from cluster, not just note
- when call is for some reason special (it has some coloring, for example) it would be good to have explanation for that
- user should be able to select presented information as text to copy it.
Re: More cluster details on right click
Post by IW3HMH » 02 Jan 2016, 11:15
copy where?
cluster notes are already copied in the QSO MESSAGE dropdown on the main user interface, to be easily selected
yt9tp
Post by yt9tp » 18 Apr 2016, 07:37
It does not matter where it could be pasted. It would be good to have option to copy.
W7DRM
Post by W7DRM » 13 May 2016, 22:33
I would second this suggestion. Especially would like to see the call sign of the spotting station and the time of the spot in the notes. Would be helpful to see where the spots are coming from and when.
I will add this to the Mantis list - for V2...
Doug - W7DRM
