Winkeyer Echo Test Failed (??)
Yes, this is the RTFM place, at your service
w0xxx
Post by w0xxx »
Good evenin',
I'm trying to get WinKeyer to talk to my IC-7600 and I'm getting the above error....am I missing a setting someplace?
Thanks in adavnce!
Tommy
Re: WK Echo Test Failed (??)
To use the Winkeyer facility in Log4OM you need a Winkeyer unit like this http://www.hamcrafters2.com/WKUSBX.html You cannot use the facility in Log4OM without one.
w0xxx
Post by w0xxx »
Very good, ironically I have one.
Now I'm able to open WinKeyer successfully, but I'm not seeing the key icon on the status bar of the logging program.
The PTT icon keys the radio fine. Do I need another cable to connect the IC-7600 to the PC via the usb port?? Its giving the band data to the logging program via the CT17.
Forget about your CT17 connection it is used for CAT control of the radio and you say it is working fine.
The Winkeyer unit connects to the computer with a USB cable which provides another com port with a different com port number to the one that you are using for the CT17 connection - YOUR COM PORT NUMBER FOR THE WINKEYER MAY NOT BE THE SAME AS SHOWN IN THE SCREEN SHOTS BELOW
The Winkeyer also connects to your radio with a simple jack plug cable into the CW socket of the radio - YOUR RADIO MENU NEEDS TO BE SET TO USE THIS KEY SOCKET CORRECTLY TO WORK WITH THE WINKEYER - SEE THE WINKEYER INSTRUCTIONS AND ICOM USER GUIDE
Select the new Winkeyer port in the Log4OM Winkeyer window as in arrow 1 below - Then click the start button identified by arrow 2
You should now see the connection is OK at the bottom of the Log4OM Winkeyer window as indicated by arrow 3 in the screen shot below
Leave the Winkeyer window open but look on the status bar at the bottom of the Log4OM window and it should show a green dot as indicated by arrow 4 in the screen shot below
w0xxx wrote:I'm not seeing the key icon on the status bar of the logging program.
The icon you refer to is probably an obsolete icon from earlier releases of Log4OM it is now placed in the 'Radio' menu with the selection 'Winkeyer'
Once all indicators show the Winkeyer active and connected as above your radio should be set to whatever CW mode you require and everything should work as designed from the Log4OM Winkeyer control centre as shown below
