Windows-XP and Windows-10 IC7300
vu2grm
Post by vu2grm » 08 May 2017, 05:20
Hi, I have been facing some issue on LOG40M : I have installed same versions 1.27.0.0 on XP and Win10. In Win10 I can see and select IC7300, on XP this is not there and with other like IC7000 etc it is not connecting. any suggestion please.
de
Ram
VU2GRM
rammohang@gmail.com
Re: Windows-XP and Windows-10 IC7300
Post by DF5WW » 08 May 2017, 07:04
Hi Ram,
this could not be a Log4OM problem so Log4OM is using Hamlib (integrated) and Omnirig
(external) for CAT. If you don´t see the IC-7300 on your Windows XP machine you may have
"older" version of Omnirig installed ??
By the way, we are meanwhile on Log4OM 1.28 ... Always a good idea to install the latest
version of a software ...
Corrected from 1.29 to 1.28 :D
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner ...
Post by G4POP » 08 May 2017, 07:43
Juergen,
The latest public release is 1.28
1.29 is currently in Alpha test and not generally available to normal users because there could be some bugs to be resolved.
Post by DF5WW » 08 May 2017, 10:39
G4POP wrote:
08 May 2017, 07:43
Juergen,
Only a problem with my fat fingers. Would write 1.28 but hit the 9 instead of the 8 :D :D
