recently, since a few days, the EQSL -image- download is not working anymore.
Example from EQSL download -Image Download- window:
22.08.2017 06:46:12: QSO updated : 5P1KZX 204400 20170821 40m FT8
22.08.2017 06:46:12: Contacting EQSL website for EQSL download...
22.08.2017 06:46:12: IMAGE request accepted
22.08.2017 06:46:12: NO IMAGE FOUND
More info: http://www.eqsl.cc/qslcard/GeteQSL.cfm? ... rom=5P1KZX........
If I open this link, the image would be there.
Is there any change by EQSL recently, I can't find any info.
Anyone else same experience ?
LOG4OM 1.30
VY 73 de Hans, DF2MC
EQSL Image download error !
Re: EQSL Image download error !
Hi Hans,
I just did an eQSL download and the image downloaded fine, see below:
22/08/2017 07:22:27: QSO updated : E73DN 143700 20170727 20m FT8
22/08/2017 07:22:27: Contacting EQSL website for EQSL download...
22/08/2017 07:22:31: IMAGE request accepted
22/08/2017 07:22:31: Downloading IMAGE document
22/08/2017 07:22:44: IMAGE retrieved OK
I can only think its a glitch at the Eqsl server because I have not had this issue recently and have not received any similar reports and a Google search does not reveal any similar issues.
Its unlikely to be your login setup because you are able to match and download the confirmation, just not the image!
Have any other users got this problem?
thanks for your quick investigation,
It is strange, just I have downloaded a amount of 17 Calls,
4 calls where downloaded as allways including images, but at the remaining calls like I mentioned before, just no image.
Seems something wrong at the E-QSL server !
Let's wait if some others have got same issue.
VY73, Hans, DF2MC
VY73, Hans, DF2MC
Hi Hans,
also no problems with image download here. Have tested this with the installed
version for my call and with the portable version for the clubcall DF0AK ...
All is working fine here ...
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Ailunce HS2 (20W and 5W VHF/UHF) to LPDA´s and different vertical´s ...
Hi Jürgen,
Thanks for the info, very strange.
I wait now, it can't be I am the only one with this issue !
73 DF2MC Hans
73 DF2MC Hans
some news about my EQSL download issue,
at one download sequence, 1 image will be downloaded, e.g, I have to pusch 3 times the DOWNLOAD button
then I will get 3 Images.
I did this several times, to get about 60 Images/EQSLs downloaded.
I have sent a request about this issue to EQSL, lets see if I will get an answhere.
If EQSL have made some changes, my problem should be happen to others as well.
vy73 de Hans DF2MC
vy73 de Hans DF2MC
Hello Hans,
i have checked this now also with a download of more than my 2 images i tried
in the first test. Same here, one or two cards will be downloaded then i have
the "No Image found" error too for the next 2 or 3 images and then the next one
or two bill be o.K. again.
Think something is wrong on the eQSL side. Let´s wait for an answere if you
have requested this on eQSL.
Download of the images is ok again, problem solved by E-QSL !
VY 73, DF2MC, Hans
VY 73, DF2MC, Hans
Thank´s for info Hans. Good news for the eQSL virtual card collectors.
B.t.w. my eQSL design for our brandnew Clubstation:
i have the same problem,do you have ask a help to eqsl staff ?
73 Frank
73 Frank
