Log40M > HamQTH upload
PD5ML
Post by PD5ML »
I'm having some problems with uploading my QSO's to HamQTH. I get the following error message and I was wondering why this happens:
HamQthManagement: The server returned an unexpected error (400) Bad Request ******* [Function: #=qtus1fzEQ9NnS1tXD_W5wQQ==] System.Net.WebException: The server returned an unexpected error (400) Bad Request
bij System.Net.HttpWebRequest.GetResponse()
bij LogOM.BL.HamQthManagement.#=qtus1fzEQ9NnS1tXD_W5wQQ==(QSO #=q$isewUVFfXqZix_NiDa$PQ==, String #=quuYeT0ZqGbJ7WSlSDml1zg==, String #=q66dKrQxK6tDxJOZOFMYsmg==, String #=qRHtpPXKHEfZej1AgRdmoYQ==, String #=q_9jOgebg5YYo4Sgx$Ht6Rw==)
2017-09-23 07:02:51.9301 ERROR: *** HamQthManagement: HamQTH SendQSO error ******* [Function: #=qtus1fzEQ9NnS1tXD_W5wQQ==] System.Net.WebException: The server returned an unexpected error (400) Bad Request
Is this an issue within HamQTH or Log40M? Anybody else has this issue?
Michiel, Netherlands
Re: Log40M > HamQTH upload
Hello OM,
first of all we prefer that users of this forum using the Call as user name and a Name in the signature woldn´t
be bad too ... ;) ;)
HAMqth was off for a few weeks so the complete database was lost by HDD crash.
Meanwhile it´s back but with a backup which is older than 2 years. So first check
out that you are registered at HAMqth. Otherwise your login data wouldn´t work.
I use HAMqth too but i am registered since a lot more than 2 years. My login is
working and also automatted uploads but our clubcall (DL0AK) i had to re register
so i added this short before the HDD´s are crashed.
That could be a possibility of your issue ... ;) ;)
PD5ML
Post by PD5ML »
Thanks for the reply. Yes, i'm registered at HAMQTH. I can upload through the ADIF file, but the upload directly from LOG4OM just gives me this bad request error. Funny thing is, that yesterday it worked with 2 QSO's.
My call btw is: PD5ML. Will try to change it.
Edit: No, it actually didn't work with the 2 QSo's. It was an success for HRD.
Hi PD5ML,
think Terry or another Team member can change the call for you. Will tell him
this by mail and maybe he has another idea related to your issue ...
Hi PD5ML,
have checked HamQTH website and you´re right. Looks like automatted uploads are not
working yet. Last contact for DL0AK is from September 15 and uploaded manual after
the re registration.
But if you are take a look to the top at the site there is an information that the side is
working in a save mode at the moment. Will ask Petr what´s wrong with automatted
uploads.
PD5ML
Post by PD5ML »
Ah phew! I thought it was just me. I will wait for the reply.
thanks!
I sent an email request to Petr. Will report here as soon as I have an answer from him.
User name changed to call sign
Answere from Petr (owner of HamQTH)
Hi Juergen,
I have no idea what could change. Also Dave, W1HKJ, author of Flidigi wrote me that he has to make some changes to his software. He had to replace lineendings to Windows line endings. I have no idea why, HamQTH is running on Linux server. Maybe something changed in Apache configuration, I'll try to find out.
73 Petr, OK7AN
I'll contact Petr.
If he cannot solve i will fix on our side
