"My Locator" field not saved in my default configuration
iu0jiu
Post by iu0jiu » 05 Jan 2018, 09:55
Hi at all..
this is my problem/bug in the log4om software.
When you have filled all fields such as "My Locator",
Log4OM not save this field as default...so you need
to re-insert each time you start the program and there is no way
to close the "Log4om Setting" window .
Let me know :?
Regards
Alex [iu0jiu]
Re: "My Locator" field not saved in my default configuration
Post by G4POP » 05 Jan 2018, 10:31
Sounds like you did not complete the 'Station info' tab in its entirety or you failed to save the configuration by clicking on the 'Floppy disk' icon at the bottom right.
Also the Locator requires a SIX digit reference like JO01jp
iu0jiu
Post by iu0jiu » 05 Jan 2018, 13:42
No, i jave filled all fields...
The problem appear when restart the software next time,
seems that the field "My Locator" has not saved by Log4OM.
Regards
A.
Post by G4POP » 05 Jan 2018, 14:32
You must use a 6 digit locator like jp01jp
Yours is the only report of this so you must be doing something wrong
Post by IW3HMH » 19 Jan 2018, 16:42
Any news on this issue?
Post by G4POP » 19 Jan 2018, 17:25
Probably because he did not use a 6 digit locator, I am sure that if he still had an issue we would have heard
