Keeping up to date
Keeping up to date
To all users of Log4OM.
Often we get in the forum (this applies to all areas) support inquiries regarding problems
that have been fixed for some time. When asked, it usually turns out that the querying user is using an outdated version of Log4OM.
Suggestions:
1. You should bookmark the forum and at least once a week to see if a new version is announced.
2. If someone knows users who also use Log4OM point out to do the same even if they are not registered. Everyone can read here. You only have to be registered in order to be able to write.
This should help to avoid some requests because the problems are already solved.
Have fun with Log4OM .... ;) ;)
And again the note:
Log4OM must be run with administrator rights to ensure the full functionality. The easiest way is to right-click on the installation file during installation and select "Run as administrator" in the pop-up menu.
73's Juergen
