Automatic BandMaster & FlDigi calls to Log4OM
IZ3XNJ
Post by IZ3XNJ » 04 Jul 2018, 19:58
I’ve wrote a small utility to send callsigns from FlDigi and BandMaster to Log4OM: everytime you click a call in the FlDigi rx window, or everytime you click a BandMap spot, the call is sent to Log4OM.
You can find my program and more infos here:
https://github.com/StefanoComelli/Call2 ... Log4OM.zip
If you need some help, feel free to contact me.
IZ3XNJ Stefano
W7DRM
Re: Automatic BandMaster & FlDigi calls to Log4OM
Post by W7DRM » 07 Jul 2018, 02:42
Stefano,
Thanks much for posting this useful utility. I installed and set it up as you directed in the help.pdf file, and set up Log4OM to start the Call2Log4OM.exe. It works great for Band Master. I could not get it to work with the -cc parameter, but eliminating that, just click on a spot in Band Master and it set's Log4OM callsign field to the call in Band Master. Very cool!
Thanks much for making this available!
Doug - W7DRM
