Strange error message when log entry deleted
VK7XX
Post by VK7XX »
I am using Log4om version 1.33.1.0
Whenever I delete an entry from my log I get a pop up window that says
"Operation completed
Not enough configured informations for uploading with
ClubLog "
John
Re: Strange error message when log entry deleted
i'll check on code. this should be linked to the attempt made by log4om to delete the QSO from Clublog also.
Was this QSO already on ClubLog?
LA9FFA
Post by LA9FFA »
Hi
I get this one if I delete a qso from my log :
I got the point.
if your Clublog informations aren't set, the system will try in any case to delete the QSO and reports the issue.
Next version will check if you have set the "upload to clublog" flag, and if yes, it will fail if you don't have set your credentials
Thanks for head up
VK7XX
Post by VK7XX »
IW3HMH wrote: 09 Aug 2018, 07:28 i'll check on code. this should be linked to the attempt made by log4om to delete the QSO from Clublog also.
No Lele, I upload to all logs manually and this contact had not been uploaded to anywhere.
John
