New Awards
ah6fx
New Awards
Post by ah6fx » 04 Dec 2018, 16:15
Have been using Log4OM for perhaps 10 years and find it absolutely superb.
Recommend adding three awards to the awards list.
1. Worked All VK Areas - HF award -- see http://www.wia.org.au/members/wiadxawards/wavkcahf/ This is different from the current Australian award on Log4OM.
2. Worked All Japan Prefectures -- see http://www.jarl.org/English/4_Library/A ... d_Main.htm ......... also see the prefecture list at http://www.jarl.org/English/4_Library/A ... ja_map.pdf ........... the more complete prefecture list is at http://www.jarl.org/English/4_Library/A ... d_Main.htm
3. All Japan Districts -- see http://www.jarl.org/English/4_Library/A ... d_Main.htm
Thanks for your consideration.
Danny
AH6FX/W4
Re: New Awards
Post by IW3HMH » 08 Dec 2018, 12:58
Hi, thanks for reporting :)
I'll check if they have a reference list that can be imported.
If possible, they will be available soon via automatic updates.
By the way i've completed a tool for porting awards from V1 to V2, as part of the work of rebuilding Log4OM so everything done in V1 will be available on V2, with more possibilites too
