Hi folks
I've found a number of FT8 contacts where either the sent or received signal report is given as +00. I've got Log4OM very successfully reading the adif file and bringing over the qsos. (It was the main reason for moving over from my old logbook software).
Anyhoo, when the report is +00 Log4OM shows it as +30. Now when I go back in and edit the report to the correct level, I notice that its just 00
Is there a way of changing this please?
thanks
Ian - M0KCM
+00 reports in WSJT-X convert to +30 ?
Re: +00 reports in WSJT-X convert to +30 ?
Ian,
A search of this forum would reveal that this has come up before, here is a link to our most relevant answer
viewtopic.php?f=5&t=3601&p=20161&hilit=FT8+00#p20239
Should you need to edit any QSO's the original reports will still be in the WSJT log file
