Using version 1.37.
My QSO manager is setup with certain fields, as is my QSL tools>QSL Manager.
My issue is that my QSO Manager and my QSL Tools>QSL Manager> Clublog are using the same set of fields, so I cannot have a separate setup for both, like I can with the other catagories in QSL Manager.
This is really not a huge deal and very easy to work around, but it was something I wanted to mention.
Love the program, keep up the good work.
QSO Manager And QSL Tools
Re: QSO Manager And QSL Tools
Did you click on the search button after changing the confirmation type?
Yes...and to make a short story long...
I have been importing adi files from WSJT-X, which do not contain all the fields I like filled in. I adjusted the fields in QSO Manager>QSO archive to contain all of those fields so I can manually update them.
As for QSL Tools>QSL management, there are only a few fields I care about, mostly the upload, status and receive dates for EQSL, LOTW and Clublog; so I made all of tabs reflect the information.
At a later date, I went into the QSO archive, all my fields were gone except for the same ones that were in QSL Management under the clublog tab.
At that point, I did a couple of experiments, adding and removing fields from each place and viola, they remained identical no matter what I did.
The work-around was easy, I simply added the clublog fields to the end of the fields I use in QSO archive. It's not a big deal at all, I just thought I would pass it along as all the other "layouts" that I have used so far seem to be independent of each other, save for these.
Mike
Mike
