ADIF import from Log4OM
sq9jxb
Post by sq9jxb » 16 Jan 2020, 15:18
Welcome All
I exported the log from Log4OM-1 in Adif 3 format (11300 QSO) and when importing into a new database in Log4OM 2 - import hangs (once at 3000 QSO, another time with a smaller number) - CPU usage increases to 90% - 657MB RAM and the end.
I did 3 tries and it's the same.
A smaller file from another log (4000 QSOs) was imported without problems
What is the reason?
Log4OM 2.2 , Windows 10 x64
Yaesu FT-897D, Icom IC-735, Musb1017, ATU-150 , SGC PowerClear
Best regards.
Jan SQ9JXB
VA3AG
Re: ADIF import from Log4OM
Post by VA3AG » 16 Jan 2020, 16:03
sq9jxb wrote:
16 Jan 2020, 15:18
Welcome All
What is the reason?
Have you changed the amout of qso's in the main UI right hand corner of the screen Max=5000 qso's. Increase the amount required records and try the import.
Good luck
Aldo VA3AG
sq9jxb
Post by sq9jxb » 16 Jan 2020, 16:11
Hello Aldo
I have changed to 15000 and it has become 4189 QSO.
EDIT:
I turned off the "Apply country correction on load" and Info Providers options and, strangely enough, imported everything without a problem - CPU usage - 45% max.
Uff :)
Best regards.
Jan SQ9JXB
OK2DTF
Post by OK2DTF » 26 Jan 2020, 11:17
My large ADIF with 6017 QSO's go not. I had to split the file into 5 parts and work it :-D Old database from v1 work not, i had create new and importing ADIF again. 73
sq9jxb
Post by sq9jxb » 26 Jan 2020, 11:23
OK2DTF wrote:
26 Jan 2020, 11:17
Welcome
Log exported to ADIF 3?
Best regards.
Jan SQ9JXB
Post by DF5WW » 26 Jan 2020, 13:41
OK2DTF wrote:
26 Jan 2020, 11:17
It was mentioned in the release announcement and in the V2 manual that V2 can´t work with the V1 database
and that it need a full new setup and a new created database. Also was mentioned that V2 can only import
ADIF 3. My QSO count is more than 24.000 and i´ve imported this sometimes to older alpha versions of V2 without
problems. The must have is an ADIF 3 file and if you have an older PC it could be help to uncheck the box
"Apply country corrections on load".
Your log isn´t so big but for test delete the new database and try to importing a fresh ADIF 3 from Log4OM V1.
73´s .. Juergen ... ALT-512 SDR (10W) , 2 x 6,5 mtr. indoor wire at CG-3000 autotuner ...
Post by IW3HMH » 26 Jan 2020, 14:48
If you have an ADIF from V1 that won't import correctly or hangs on import please send it to me at log4om @ gmail (dot) com
Please add a brief note to the mail with link to this thread so i can understand why you're sending it :)
OK2DTF
Post by OK2DTF » 26 Jan 2020, 14:59
sq9jxb wrote:
26 Jan 2020, 11:23
OK2DTF wrote:
26 Jan 2020, 11:17
Welcome
Exported to ADIF 3 stay in file and Log4OM v1.40 :-) In v1 i had import as ADIF 3:
<ADIF_VERS:5>3.0.4 <PROGRAMID:6>Log4OM <PROGRAMVERSION:8>1.40.0.0 <eoh>
v2 have problem with large ADIF but in v1 no problems all time :!: Old database i mean SQLite file. If worked right, after are all QSO's easy back but work not and needed import ADIF again :lol:
OK2DTF
Post by OK2DTF » 26 Jan 2020, 15:02
IW3HMH wrote:
26 Jan 2020, 14:48
Still imported as small files, only old SQLite database working not, need create new and import all ADIF's back ;)
OK2DTF
Post by OK2DTF » 26 Jan 2020, 15:07
Need help with another viewtopic.php?f=6&t=3670 :!:
