Under cluster management there is internal server. What is this?
What is internal Server
Re: What is internal Server
With the server you can send received spots onward, perhaps to other software or band maps or even to superimpose on a panadaptor waterfall
If you have a PC local network with only one internet connected you can share your cluster(s) through the internal telnet server, using it as a normal telnet cluster.
All incoming messages from local clients will be forwarded to the cluster marked PRIMARY in the config
