Cabrillo
Re: Cabrillo
No, there are plenty of on line ADIF to Cabrillo converters or you can use N1MM which will provide the file and log to Log4OM
Re: Cabrillo
I was surprised to see that this was not an option in Log4OMv2. I am not a contester by any means, but as a contest mode is offered in Log4OM, I thought the lack of Cabrillo export in v2 strange.
Take care and stay safe.
Re: Cabrillo
As you said... It is a contest mode but V2 is not a real contest logger. These kinds of loggers can handle multipliers and the calculation of the points. Make sense that these are have Cabrillo or STF.
If I work in a contest i only use real contest loggers and import my ADIF later if the used contest logger does not support UDP connection to our V2.
Think that is the better way for contesters which like to upload their logs and fighting for points ...
Re: Cabrillo
Thanks Juergen, I understand now.
