I recently upgraded to Log4OM V2 version 2.14.1.0. Ever since the upgrade, I notice that when working FT8 using JT Alert, when a call sign is sent to Log4OM from JT Alert, the statistics pan on the main UI does not populate. Deleting the call sign from Log4OM and pasting it back in again, the statistics pane populates. Other times, the statistics pane populates normally when the call sign is sent from JT ALert. I am attaching a realtime log snippet from a call sign that the statistics pane did not populate on. It appears that when a call sign is entered manually, it works every time.
Brad, N4PYI
Statistics Pane does not Populate Log4OM V2
- Log4OM_log_20210629215911.txt
- (8.57 KiB) Downloaded 128 times
Brad, N4PYI
Brad, N4PYI
Re: Statistics Pane does not Populate Log4OM V2
I haven't seen any replies to this, Terry I wondered if you have any thoughts?
N4PYI, Brad
N4PYI, Brad
Brad, N4PYI
Brad, N4PYI
Brad,
FYI - install the current release of Log4OM V2. It is: v2.15.0.0
I don't recall Danielle making any changes that would impact what you have described, but update it anyway and advise.
Also ... are you using WSJTx or JTDX with JTAlert?
A list of your APP configuration and connections to Log4OM will be helpful.
Brad,
Just did some testing ... as best I could from your initial post.
I followed the settings in our User Guide for using JTAlert. They start on Page 205 of the "current" User Guide.
I used WSJTx (current Beta release) and current JTAlert. JTAlert is feeding the data from WSJTx through JTAlert and then into Log4OM V2.
I double-clicked on a call in the JTAlert callsign/window panel and that data immediately populated the Log4OM V2 Main UI. I tried several different calls and captured images of two of them and have attached them below.
Seems to me that statistics did appear. Could you provide similar screen clips of what your installation looks like without statistics?
- FTxx_statistics_MainUI-2.JPG (111 KiB) Viewed 2388 times
- FTxx_statistics_MainUI.JPG (107.91 KiB) Viewed 2388 times
Nolan,
I am running WSJT-X version 2.3.0 with JT Alert 2.16.17 (No, I haven't sprung on 2.50 yet). I had recently upgraded Log4OM to V2.14.1 and that is when I noticed this behavior. It was not in the cluster screen as your screenshots showed, it was in the Main (F6) Screen with the statistics pane on the left. When double clicking on a call in WSJT-X, teh call would populate the upper pane with all the info etc, but the statistics pane would not. If you deleted the call fromteh input box and pasted it back in, the statistics pane would populate. (Screenshot attached) I was not aware there was a newer update for Log4OM, so I just installed 2.15.0 and ran about a hal;f doxen QSOs on FT8. The statistics pane is working again. Could have been a burp in the install of 2.14.1. I will ring it out over the weekend and see if it comes back. Hopefully not!
Thanks for the reply.
Brad. N4PYI
Brad. N4PYI
- Statistics Pane Does not Populate2.jpg (217.5 KiB) Viewed 2381 times
Brad, N4PYI
Brad, N4PYI
Brad,
Ahh ... the statistics panel I seldom look at. One of the reasons all of us, on the Alpha Team, ask for screen clips of what y'all are looking at.
That data display (or lack thereof) was an issue and corrected with the new release (v 2.15.0.0). Of course internally we had about 9 versions we were testing from 2.14.1.0 to 2.15.0.0 so I lost track of that issue.
Screen clips are one of the best tools.
Hope you continue to enjoy Log4OM V2.
Nolan,
I ran about 50 or so QSOs on FT8 this morning and Log4OM had no issues, version 2.15.0. Statistics pane worked everytime.
73 & Happy 4th
Brad, N4PYI
73 & Happy 4th
Brad, N4PYI
Brad, N4PYI
Brad, N4PYI
Brad,
Tnx for the update and follow-through.
