I'm having an issue with the needed countries color not appearing as it should, in this example, YI1BGD is needed on 10m as a new country but no color code appeared.
I'm attaching both screen shots
Cluster needed award colors coding not working (for me)
- setting.png (92.41 KiB) Viewed 1894 times
- cluster.png (150.5 KiB) Viewed 1894 times
Re: Cluster needed award colors coding not working (for me)
LOG4OM Version number ????????????????????
You don't have country field displayed in grid, its that field that will be highlighted
Still no color
- cluster2.png (139.8 KiB) Viewed 1877 times
Check filter tab in box to right
Here is the filter setting
- Screenshot 2023-04-21 211454.png (17.15 KiB) Viewed 1857 times
any news about this bug? anyone could see this problem?
Not a bug because it works fine except for you as you can see from my screen shot below the band/mode not worked is highlighted yellow and is displaying as such in cluster.
Suggest you try unchecking the 'Keep band on mode' box and display the correct columns for band and emission type, not just frequency.
None of your screen shots display those columns and they are where the highlight will be seen - Not the frequency column, check user guide for information
I have done what you told me and now it is working as expected.
Thank you
Thank you
