Log4om logging W8S as USA
How to fix to log KH8S?
I changed manually for swains island
But next QSO wrong again???
Wrong DXCC
Re: Wrong DXCC
Has already been discussed on another thread here in the Forum.
You must not be using the most current version of Log4OM. Pls advised that.
Another OM (also using an older version of Log4OM) changed the order of the Info Providers.
See this link: https://forum.log4om.com/viewtopic.php?t=8697
Re: Wrong DXCC
Yes
But why not write HOW to edit it to permanently??
I changed to correct DXCC, still wrong
Strange not possible to answer how to fix a issue.
I am running latest update..
I want to know how to choose correct fix to add a callsign hookup to a new DXCC without using clublog or any other sources…
Re: Wrong DXCC
Are you shure that W8S is correct for the next Swains Expedition ? Normally it´s a US Callsign that is used for this Swains operation.
Next time it could be a special US call. Same with some DXpedition Calls of the french territories. That means that next time you
work this calls it could be a national special call or another Island/Territory and you have a wrong DXCC again. So easiest way is to
use clublog to check out for the correct DXCC.
Re: Wrong DXCC
FWIW, I am using latest version of LOG4OM and all my W8S contacts were correctly logged and applied.
Re: Wrong DXCC
Also using the latest version of LOG4OM and W8S is correctly logged. Suggest you reinstall LOG4OM.
Good luck!
73 Bert VE3NR
Good luck!
73 Bert VE3NR
Re: Wrong DXCC
or maybe update the cty.dat file. it depends on where the wrong country is being obtained from...
