integration JTDX-JTALERT-GRID TRACKERS-LOG4Om
Here we will provide support for developers working on integration
F5PLR
Post by F5PLR »
hello everything works well I have a small problem sometimes I have an error message and sometimes no it tells me that the qso is not recorded on the log4Om even though everything is good.
On the other hand, the qso's do not go directly to QRZ.COM and Club Log whereas in the direct contact version with the cross it works very well 73 Didier HI9/F5PLR
ve3tos
Re: integration JTDX-JTALERT-GRID TRACKERS-LOG4Om
Post by ve3tos »
Had the same issue. In JTAlert go into settings, LOGGING. From there you will see the option "Check QSO Log Record" I changed mine to "15 Secs" and that avoided the issue.
2023-10-30 10_47_22-Window.png (44.57 KiB) Viewed 79788 times
