H26 - Helvetia 26 HF-Award
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the H26 - Helvetia 26 HF award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_H26.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM. The latest version of Log4OM will update all awards automatically.
More information regarding the award can be found here: http://uska.ch/fileadmin/download/Diplo ... iplome.pdf
Claus, EI7JZ/OE6CLD
award_H26.xml
H26 Award
(17.46 KiB) Downloaded 776 times
Claus, OE6CLD/DJ0DX/EI7JZ
