Award with different calls - same qth
Moderator: OE6CLD
on6at
Post by on6at »
I have different callsigns.
In the User Configuration I have the call ON6AT, OO6AT, OT6AT and OR6AT. These are callsigns with the same QTH.
I have to create different database because I also use Eqsl, Clublog and others.
Otherwise they will not be sent to the server.
Now I want to count all these callsigns in the Award section.
Example: DXCC of ON6AT + OO6AT + OR6AT + OT6AT added together.
Is this possible?
73 Patrick ON6AT
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Re: Award with different calls - same qth
Already there
Select an empty or blank to show all call results grouped
Select single calls to display results for just that call
on6at
Post by on6at »
Thank you for the explanation Terry.
BUT I have 4 different databases in Configuration> User Configuration.
Configuration ID xxxxxxxxxxxx Active with callsign ON6AT
and Configuration ID yyyyyyyyyyy Active with OR6AT.
I have to work like this, because for Eqsl I have a different login and password than for OR6AT.
73 Patrick ON6AT
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Patrick
Providing the owner, operator and station call fields are completed in each data base I would combine them into one common log
Just use different config for the EQSL upload details but the common database
When you upload filter by call sign in whichever config and upload
I do this for my calls G4POP, G6CNQ, GB4VED, GB4GMF etc and it works fine
on6at
Post by on6at »
I'm trying to understand this.
I have created 1 database, but how do you create different Eqsl login passwords?
Can you give an example of that?
Thanks in advance for the support.
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Patrick
Create a different user configuration for each call sign with the relevant eqsl login data
See page 20 of our user guide 'Multiple Configurations (Identities)'
on6at
Post by on6at »
All work fine now, thanks
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
