I find the current method of recording audio messages to be quite clumbersome and would like to be able to edit recorded files with a programme like Audacity. In N1MM you can separately record WAV files and then save into the appropriate folder. I have files for my callsign, calling CQ, Exchanges and so on. I would like to see a way to use ones own WAV files for sending audio messages in Log4OM.
Peter G3ZSS
Audio Keying - and recording messages
73 Peter G3ZSS
- VK7XX
- Old Man
Re: Audio Keying - and recording messages
a good idea... add me to this request.
John
VK7XX
John
VK7XX
Files are saved in the configuration folder, in a separate subfolder...
Simply create the audio with Log4OM, add relevant informations then replace the .wav file with the one you registered.
This is the faster workaround i can suggest now...
