Hello i have install Log40m it looks verry nice.
But i have one problem, i cannot connect with my icom 7600.(usb)
I have try Hamlib/omnirig it will not work.
When it is connect he disable in 10 sec automatic.
Cluster is working correct en also import ADIF is no problem.
Cat status is RED
Ic 7600 cat control Hamlib/omnirig not woking
Re: Ic 7600 cat control Hamlib/omnirig not woking
Are you sure that you have selected the correct com port and baud rate in Omnirig?
What is your call sign?
Yes, com1 and baud rate 9600 stop bits 1.
(Try Omni-Rig and connect by selecting ICOM model IC-725a)
I have try this but also not works for me.
I have try also com 14 but it will not working for me.
what port and baud rate for HRD?
CALL SIGN PLEASE
CALL SIGN PLEASE
In the Icom menu check the "USB Serial Function" is NOT set to Decode, it should be set to CI-V.PD1EHA wrote:I do a compleet new reinstall now i let jou now.
NO i,m sorry it will not work.
I stop now till there is a solution to solve this problem.
I have check it and it is on CI-V
Ok i have try it again and i have cat connection pfffffffffff unbelieveble but it works,
