Band Map
K0HB
Band Map
Post by K0HB »
A band map would be a nice addition, clickable to take you to the spot QRG.
DE Hans, KØHB
"Just a boy and his radio"
Re: Band Map
We have plans to enhance the existing clickable band map with a definable tuning scale at some point but its a little way off because there are many other things to do first - It's on our Mantis list
OE6CLD
Re: Band Map
Post by OE6CLD »
I also would love to have a band map within Log4OM but I don't think it will be necessary to invent (program) this over and over. A don't think anything comes close to Band Master from Alex VE3NEA (http://www.dxatlas.com/bandmaster/) and this program offers a COM/OLE interface.
Wouldn't it be easier just to provide an interface?
Thanks for this great program!
Claus, EI7JZ
Claus, OE6CLD/DJ0DX/EI7JZ
Re: Band Map
EI7JZ wrote:Hi,
Claus, EI7JZ
Hi Claus,
Yes this is something we can discuss and perhaps is a possibility but we are still someway from getting to that.
I am fairly sure, but will check, that Bandmaster will work with a VSP so that is a temporary way you could use it!
Re: Band Map
Hi Claus,
I really must engage my brain before opening my mouth :D :D
Alex also provides Omnirig so Bandmaster already works 100% in unison with Log4OM if you are using Omnirig for CAT control. See the screen shot that I just grabbed.
Sorry for being a plonker :oops:
CT1BXX
Re: Band Map
Post by CT1BXX »
Thanks Terry,
What a wonderful message! :D
Later I will install , because I was looking for it, now you give us the solution, thousand thanks for your message.
Have a nice day.
73 Manuel
73 Manuel Fernando CT1BXX
OE6CLD
Re: Band Map
Post by OE6CLD »
Thanks! I did not think about this myself :(
The best logging program with the best band map available, great! Now I only need some more support for awards (WAS, WAZ, DOK, WAE, ...) to be completely happy :)
Claus, EI7JZ
Re: Band Map
EI7JZ wrote:The best logging program with the best band map available, great! Now I only need some more support for awards (WAS, WAZ, DOK, WAE, ...) to be completely happy :)
Claus, EI7JZ
All in good time we are working on many refinements and new features so eventually you will have what you wish for
OE6CLD
Re: Band Map
Post by OE6CLD »
Last weekend I had the time to play with both Log4OM and Bandmap. Frequency integration was working fine, a double click on a spot in the bandmap resulted in a frequency change in Log4OM.
For a full integration I want Log4OM to take over the callsign I double clicked in the bandmap. It should work the same way like the build in cluster. I think there is some more work necessary to implement this interface but it still should be much easier than coding a complete bandmap from scratch. I also like the quick band change buttons available in Bandmap, they are working like a charm.
Claus, OE6CLD/EI7JZ
