I understand that, and I personally like the way Log4OM handles LoTW, so let's ignore that for now. However, let me use RUMlog (on OS X) for an example (or HRD) regarding eQSL. Using RUMlog, each time you download new QSLs from eQSL, it doesn't show all of the QSOs, it only displays the QSLs received on eQSL since the last time you checked. Obviously, RUMlog keeps track of when eQSL was last checked, and it only displays eQSL confirmations received since that time. So, either RUMlog is:G4POP wrote:k3dcw wrote: I know that other logbook programs don't have this issue for some reason (maybe they filter the downloaded ADIF file to remove "dupes"), so that's why I was asking.We can only download using the protocol provided by LOTW and eQSL this applies to all developers.
a) downloading all eQSL QSLs since the beginning of time, and filtering out any that it has already seen and then showing only any "new" ones in the dialog,
or
b) there is some way to just download eQSL QSLs received since a certain date.
I honestly don't know which way it is being done; you and Danielle will have a much better grasp on the eQSL developer info than I. However, I know that when I download from eQSL in RUMlog today using the same log as Log4OM, RUMlog shows me at "0" new eQSLs as of today, but in Log4OM it shows 179 or so eQSLs received based upon QSOs over the last 6 months. Log4OM doesn't make any changes because all of the QSOs are already in the database, so that's ok. But, there is no way to know if any of those 179 are new or whether they are all "old" QSLs received previously. In RUMlog (or HRD), if I see one downloaded then I know it is new.
You said that eQSL's documents say this is the way it has to be done, and I'm not arguing. I just wonder what other programs (like RUMlog, or HRD, or DXLabs) are doing differently to hide all of that extra data being downloaded, or is there another way to get the info that was perhaps overlooked???
In any case, I appreciate the effort and the discussion. Discussion is what helps formulate ideas and feeds them through the "fire" to forge better products...and Log4OM is definitely a great product!
73, Terry, and thanks again for the info and for listening!
Dave
K3DCW
