NPOTA (National Parks on the Air)
K2RAS
Post by K2RAS »
Do the developers plan on creating an award for the National Parks on the Air 2016 program in the near future? Just wanted to check before I go through all the work of trying to do it myself.
Thanks, Ron
K2RAS
Re: NPOTA (National Parks on the Air)
No we have no intention of hard coding this award.
It is just this type of award that we provide the user defined awards for (Award Manager)
K2RAS
Post by K2RAS »
Ok, thanks. Just checking.
Ron
K2RAS
Post by K2RAS »
Ok, I created a file and successfully used it to upload and create the NPOTA award in Log4OM (485 references). If anyone wants it I can post it to the thread.
In return, can anyone provide me some direction on how to create a custom expression to highlight only missing references in the Cluster Window? I presume the expression would work either in the Cluster Window or as an Alert.
Thanks, Ron
K2RAS
email me the award xml file and I will see what can be done
g4pop (AT) arrl (dot) net
Ron has generated the award file which has been forwarded to our awards manager Clause for inclusion in the default awards set.
Lele and I have derived a regular expression for the DX Cluster custom highlights which will be included in the default set of custom highlights for the next release
K2RAS
Post by K2RAS »
Thank you!
Ron
K2RAS
N4xyz
Post by N4xyz »
Ron, I would like a copy of the XML file for the award manager. Please send me a copy to n4xyz at ARRL dot net.
Tax
Dave, N4XYZ
N4xyz wrote:Ron, I would like a copy of the XML file for the award manager. Please send me a copy to n4xyz at ARRL dot net.
Tax
Dave, N4XYZ
If you update the awards in Log4om it is probably there already for download, because Claus said he would make it available yesterday
you should remove your own NPOTA award (if any), because it may conflicts with official one downloaded from net.
