Database Query Help
HB9BRJ
Re: Database Query Help
Post by HB9BRJ »
It looks as if custom search can handle quite complex SQL expressions. Here is an all-band version of my previous 160m solution:
Code: Select all
(Band = '160m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '160m')) Or (Band = '80m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '80m')) Or (Band = '40m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '40m')) Or (Band = '30m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '30m')) Or (Band = '20m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '20m')) Or (Band = '17m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '17m')) Or (Band = '15m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '15m')) Or (Band = '12m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '12m')) Or (Band = '10m' And Country Not In (Select Distinct Country From Log Where (LotwQslRcvd = 'V' Or QslRcvd = 'Y') And Band = '10m'))
73, Markus HB9BRJ
One of its biggest strengths Marcus
w0ls
Post by w0ls »
Once again...THANKS Markus. I plugged that script into custom search and saved it and of course it works great. Log4OM is certainly flexible and powerful.
73's
Harry
W0LS
Well, this feature was created to provide more "advanced features" to skilled users.
And reporting those informations is something that made me happy. This is, as Terry said, a perfect p2p support.
I love building Log4OM with powerful features, hard to use sometime, but extremely powerful if well used. It's a great satisfaction when someone plays with queries or regular expression engine :)
In V2 there will be possibility to type a query directly into log4om and show result in the usual Log4OM grid. Hopefully there will be no needs to have a sqlite/mysql software, except in case you need something more than query your database.
