increase layout width limited size
Unfortunately the layout width in F6 and F7 is limited as described by k2jf already in USER SUPPORT. I suggest to increase it. In the attachment the current limiations are obvious in the gray fields:
- LO4OM-column.JPG (125.62 KiB) Viewed 10289 times
73 Olaf DK2LO
Re: increase layout width limited size
Try adding a field after comments in the layout, then you can make layout as wide as you like
- Capture.JPG (63.17 KiB) Viewed 10285 times
Thank you Terry,
this is the trick and it works fine. I think Phil will also like this feature.
73 Olaf DK2LO
ups... not good... must check that...
anyway the workaround works...
This solved a little problem for me, while we are in log window it would be good if different colour apart from grey could be selected, would it be easy to do in a future release?
Pete
Pete
Something odd is happening I tried to swap comments and distance around (up/down) then hit refresh. columns remained the same 1.16.0.0 is there any way I can alter width of columns?
Pete
Pete
Layout/column widths and remember to click save icom
1.16 layout work fine I just checked
Thanks Terry
Pressing save does help
I have a problem with eqsl download can I mention it here or start a new topic?
Pete
Pete
Start a new topic please2E0KEH wrote:Thanks Terry
Pressing save does helpI have a problem with eqsl download can I mention it here or start a new topic?
Pete
Please open a new thread, so we can give more evidence to it, for other ppl with the same issue
