For some reason, I am unable to sort by date range in LABEL PRINT. The QSOs are in my log. What am I doing wrong ?
73 de Gord, VE3CNA
UNABLE TO SORT BY DATE RANGE IN LABEL PRINT
Re: UNABLE TO SORT BY DATE RANGE IN LABEL PRINT
Hi Gord,
Not sure I understand. Are you referring to sorting by date, or setting a filter by date range?
If you mean sort by date, you can do that on the QSO Selection tab of Label Management by clicking on the date field.
If you mean set a filter by date range, you can do that with the Filter by date checkbox and setting the date range. It works for me.
Doug - W7DRM
Doug - W7DRM
Hi Doug: It will not work either way ! I was able to select a range of QSOs and then printed the labels OK. I then selected another date range and all it shows is 10 Qs and none in the date range.
I am thinking that something has been corrupted because my Qs went through some kind of sort and I had to click on 'refresh' to get them back in order.
So now, I am unable to get the Qs shown on the screen to select those I want to QSL. Right now, I am thinking of uninstalling LOG4OM and starting over.
Thanks for your help. Any thoughts ?? 73 Gord
Doug: I am unable to find a heading LABEL MANAGEMENT....................... ??????
Gord
Gord
Sorry, FOUND IT. Still no good. G
Gord,
Do you have Skype installed, or TeamViewer and free calls to the U.S.?
Doug
Doug
Sorry I do not. Gord
If you can install Skype, I can contact you via Skype and walk you through a solution.
Doug - W7DRM
Doug - W7DRM
Hi Doug: I will telephone you. my expense. send me your tel. number. Gord
Gord,
I've sent you an email with my contact information.
Doug - W7DRM
Doug - W7DRM
