Comm Services stops working
VK3SIM
Post by VK3SIM »
Hi, I am having trouble with the comm service stopping and the TCP connection to LOG4OM stopping also, It will be fine for an hour or so then it will drop out I will start everything up again but it becomes more frequent.
I set log4om up to prepare a logfile and the comm services dropped out about an hour later when I clicked on a spot so I saved the bug report and I also had 2 error messages in the communicator activilty log.
05-07 23:05:56.2723 ERROR: *** TCPClientManager: Error reading from socket: [SerializationException] Binary stream '0' does not contain a valid BinaryHeader. Possible causes are invalid stream or object version change between serialization and deserialization. ******* [Function: ClientSocket_PacketArrived] System.Runtime.Serialization.SerializationException: Binary stream '0' does not contain a valid BinaryHeader. Possible causes are invalid stream or object version change between serialization and deserialization.
2016-05-07 23:05:56.2773 ERROR: *** TCPClientManager: Socket error during Read: [SocketException] A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied
Every program is run as administrator
I am running
WINDOWS 10 PRO
LOG4OM 1.25.0.0
OMNI-RIG 1.16
PSTROTATORAZ 12.32
FLDIGI 3.23.05
WSJT-X 1.7.0-DEVEL R6342
JTALERTX 2.6.1
TQSL 2.2.1
Thanks in advance
Simon
VK3SIM
Re: Comm Services stops working
Please enable the 'Trace' in Help/Debug mode
Run the program until the TCP issue happens
Send the Help/Send Bug Report to me or Lele, please include the ADIF file
VK3SIM
Post by VK3SIM »
Fixed the problem buy changing the poll int in Omni-Rig from 100ms to 700ms.
Thanks for your help.
Simon
