Sorry ran into two snags I cant seem to figure out with using all these new apps for me. I am uncertain if my problem lies with Log4OM but take a look any help appreciated. This is two questions for help.
A) Log4OM and QRZ I am selecting to send/update QRZ with the new QSO but nothing seems to happen, no confirmation, no error just nothing. QRZ is not updated with new info. I have my user and PW info selected correctly in the settings not sure what to do?
B) Log4om and JT65 HF HB9HOX 3.2 I selected the Log4OM log for JT65 to use instead of default. The location is correct however when JT65 loads in stays in a Please Wait state which it never gets out of, when I switch back to default log all is well. I used an existing log and a blank log with same results. I would sure like this integration to work just like FLdigi is with Log4OM. Any help appreciated!
KG5PIO
Log4OM with QRZ and JT65 HF HB9HOX 3.2
Re: Log4OM with QRZ and JT65 HF HB9HOX 3.2
You need to be a PAID XML SUBSCRIBER to QRZ and then you get issued an API code for uploading your QSO's - You do not use your password for uploads
JT65 HB9HQX accesses the Log4OM database directly. No need to launch Log4OM. When launching JT65, the Log4OM database must exist at the path specified. If not, QSOs will be added to the default JT65 log. Launching Log4OM manually while JT65 is running is OK here. Guess your Log4OM is launching JT65 too early. The database may still be locked by Log4OM. Increase the delay, or launch JT65 before Log4OM.osros wrote:Sorry ran into two snags I cant seem to figure out with using all these new apps for me. I am uncertain if my problem lies with Log4OM but take a look any help appreciated. This is two questions for help.
Other idea: I assume you are using OmniRig. Hamlib can only handle one app at the same time.
Markus HB9BRJ
