Possible Bug in Latest version
WA2SQQ
Post by WA2SQQ »
Terry
I just upgraded to the latest version. I've been working the Spanish special event stations. I'm noticing that, randomly, worked stations are not being highlighted as "worked" on the DX Cluster. See attached photo. AN400M was worked, and noted so in the Callsign field. On the cluster screen it is not marked, in green, as are other worked stations
log 4 om Error.jpg (100.75 KiB) Viewed 7711 times
Re: Possible Bug in Latest version
WA2SQQ wrote:Terry
I just upgraded to the latest version. I've been working the Spanish special event stations. I'm noticing that, randomly, worked stations are not being highlighted as "worked" on the DX Cluster. See attached photo. AN400M was worked, and noted so in the Callsign field. On the cluster screen it is not marked, in green, as are other worked stations.
Strange it works fine for me, I suppose that you are waiting for the next cluster refresh for it to highlight the cluster entry as worked?
WA2SQQ
Post by WA2SQQ »
It's not doing it with every contact which is why I mentioned randomly. Last night I made 12 contacts and it occurred 2 times.
Does any other user have this issue - Please respond if you do!
I noted that I was experiencing this same situation this afternoon when I was also getting Q's with the AN400-'x' stations.
I've refreshed and changed display taps several times and is not indicating "worked".
FWIW: Both of my Log4OM installations are new (v1.26.0.0) as I've been trying to trouble-shoot other issues related to SUB/Serial signals being sent to my K3. I've done very little modifications to the app (as of now anyway ... ;) )
I am beginning to think that this could be due to ether our user or the person spotting occasionally using an O instead of a zero when entering AN400xx as this is not reported on any other callsigns just this particular series of calls.
CT1BXX
Post by CT1BXX »
G4POP wrote:Does any other user have this issue - Please respond if you do!
I confirm, I have same error here.
73 Manuel Fernando CT1BXX
The issue of 'Worked before' not working Manuel ???? and if so is this only for AN400xxxx calls?
or
IOTA highlights?
CT1BXX
Post by CT1BXX »
or
IOTA highlights?
Sorry Terry I was not clear about the problem.
Only IOTA highlits
Have tried to force this error here with the spanish special calls but no chance. All is working perfectly. I use some other colours for the "worked on same band" spots but here all is working as it should.
