CLUSTER HELP
CLUSTER HELP
hi i watched your you tube on the cluster and have added some custom items along thel lines you have but when i click on the test button i get a little red box with a KO in it and theres nothing in the test string for any of them hence i presume why its not working can you help also awaiting part 2 of the you tube vid best 73s
Re: CLUSTER HELP
Clearly there must be something wrong with the regex string that you entered.
Providing an example of the string that does not work and it's purpose would help?
