Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
Additional Layout item for Recent QSO window
Re: Additional Layout item for Recent QSO window
I believe you are overlooking it in the list of fields, it could be down the bottom, because its working fine for meVK7XX wrote:Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
- VK7XX
- Old Man
OMG how embarrassing.... you are right Terry, thanks. Yes, it was right down the bottom of the list out of alphabetical order. Next time I will look at the whole list.G4POP wrote:I believe you are overlooking it in the list of fields, it could be down the bottom, because its working fine for meVK7XX wrote:Today I was attempting to add another column of information to my Recent QSO window (version 1.26.0.0) and noticed that it does not exist... that is, QSO End ... 'QSO Start' is there, and 'QSO end date' is there, but not 'QSO End' (the qso end time as seen in the Update QSO info window when you go to edit a contact)
regards
John
VK7XX
regards
John
Tasmanian Devils at work again, devious little swines
