Communicator stops and Problem with 1.27.0
I use:
Log4OM v 1.26.0
WSJT-X v 1.70
JTAlertX 2.8.7
PstRoatorAz v 12.41
Windows 10 64bit
It all works great and then it will stop and I can’t log a contact or control the rotor.
I have not found and common item that would cause it to stop?????
Sometimes it will work all day and then others it will stop at the drop of a hat.
I can bring up the Communicator and restart it and it will log again but the Rotor will never restarts.
Another thing is that when I loaded the new ver. 1.27.0, I could not log a contact from JTAlert.
I had to reload 1.26.0 again.
Paul NA4MM
Re: Communicator stops and Problem with 1.27.0
Do you have all running as "Administrator"
Yes, they are running as Administrator.
Paul NA4MM
Paul NA4MM
