Lead-In setting in Winkeyer window
N9LQ
Post by N9LQ »
I think there is a problem with the lead in function in the Winkeyer window. When I set the number to 10 ms, it is actually taking 10*10 ms for a total of 100ms lead in delay, as measured on a scope. Unfortunately, the user interface won't allow me to enter the numbers 1-9 to achieve lead in times of 10-90msec.
I can use the winkeyer utilities (WK3TOOLS) to set the lead in value to 2 (20ms) for example, but when I try and use it from within the Log4OM winkeyer window, it seems to overwrite the value with 10 (100ms).
I am running windows 10, and the latest version of Log4OM (1.27.0.0). Thanks!
73, Joel
N9LQ
73, Joel N9LQ
Re: Lead-In setting in Winkeyer window
Referred to Daniele
Lead In and Tail increment changed from 10 to 1 per click.
Thanks for reporting
