Don´t have awards
Don´t have awards
I can´t see any award
- a2.JPG (33.83 KiB) Viewed 9742 times
- A1.JPG (44.54 KiB) Viewed 9742 times
Re: Don´t have awards
Have you downloaded the awards database from Settings>Awards Database? Try that.
Did you click the drop down to see if the list is there, nothing will show until you do because there are many awards applicable to a call sign
I assumed he had looked at the drop-down and it was empty. I know what "assumed" spells!!!! HiHi
He may have assumed that it was empty or that it should auto populate but which award should we populate it with ?
It´s empty for all callsigns and I download the last updates.
The program always work correctly. I assume that has been due to problems arising from the last windows update
In C:\Users\YOUR USER NAME\AppData\Roaming\LogOM do you have a file called 'awards_user.xml' or similar?EC1AIJ wrote: 27 May 2017, 05:22 It´s empty for all callsigns and I download the last updates.
If not then email me and I will send you an awards file to import
Do not post Team viewer user names and passwords on this forum - Direct EMAIL to the recipient only to preserve your security
