23cm SSB issue
MM0ZIF
23cm SSB issue
Post by MM0ZIF »
Hi I am running 23cm SSB and I get a red out of band indicator, which is not correct, can anyone tell me how I correct this error please
de MM0ZIF
Marcus
Re: 23cm SSB issue
Yes by adding it to the
bandplan_dxcc223.xml
bandplan_r1.xml
bandplan_r1_user.xml (if you have one)
which are located at C:\Users\YOUR USER NAME\AppData\Roaming\LogOM
