data base???
KG5GXF
data base???
Post by KG5GXF »
I have downloaded this program and thought I had everything done but when I go to use it, it says I am not linked to any data base... What am I not doing???????? KG5GXF Raye 73
G4NVB
Re: data base???
Post by G4NVB »
Did you create a "New Database" see "Starting a new Logbook" in the Help File?
73 de David G4NVB
Re: data base???
KG5GXF wrote: 04 Jul 2017, 15:28 I have downloaded this program and thought I had everything done but when I go to use it, it says I am not linked to any data base... What am I not doing???????? KG5GXF Raye 73
You might benefit by watching our YouTube Quick start Guide or downloading the PDF version?
You need to create a database (Logbook) before you can start to add QSO's
File/Create new database
Select a location like a cloud storage or in your documents folder
Give it a name and save!
Now you will be able to add new QSO's
